Advise on how to model this sheet metal part
mooreaa
Member Posts: 5 ✭
Hello,
I'm looking at modeling up a firewall which is a sheetmetal part, but the flange around the perimeter is curved. I am curious what the best way to model this is. It has a lot of tabs and that are cut and folded and curved before being riveted in. It would be really nice to have that geometry be slaved to the outline of the overall panel somehow if that makes sense, or at least driven by a curve, but the only way I can see making those curved flanges is to manually extrude/bend out each section.
Some of the flanges could also be formed with a tucking/shrinking method. My ultimate goal is to just have a model representation of this part so that I can pull a flat pattern from it.
https://cad.onshape.com/documents/feeafb87e93684b0f10c813b/w/ceb86e65fb96e6e9065eea91/e/19d921cb77ceccac3d639ba1
@mooreaa
Probably to late with this post, But maybe you might want to go about it this way.
ALSO THE BELOW VIDEO
https://www.youtube.com/watch?v=vmoB3h4V6hk
Or you could scan and send out a file to these guys where you wouldn't need tabs
But this way would likely be pretty expensive
https://www.youtube.com/watch?v=bD6zyEhrYfU
