bend face, or i dont know help
lászló_sipekilászló_sipeki Member Posts: 9
Hello
I made a cap, but the sides need a bend, and i cant figure out how to do.
I attached the picture how it looks like, and the part how looking now.
  • jelte_steur814jelte_steur814 Member Posts: 464 PRO
    make a sketch with this shape in the plane of these pictures and intersect it with the first extrude.
    do that before the chamfers, drafts etc.
  • lászló_sipekilászló_sipeki Member Posts: 9
    Yes i try it, but because the top is curved.
    The top edge not just a line.
  • MDesignMDesign Member Posts: 836 ✭✭✭
    Like this?
    Hello
    Yes, but in the mean time i solved with revolve, because the top face also curved on the side.
    But now i have another problem with the chamfer, first i try to move and rotate the face, but thats make a small width.
    So i cut more piece, and rotate every piece just a bit.
    But now this corner top is to fragmanted, any idea how can i make a nice even bended corner like this but without fragmantation?
    Without access to your document it will be hard to determine the cause of fragments. You will have to provide a link so that everyone can see what you did to get to the point you are.
    Yes sorry,
    https://cad.onshape.com/documents/52de6fad944bd4b95baa8495/w/eb4c333cf164371e5a21c866/e/0f9c4c11e6fbf558c98d3342
    i made some plane and cut the faces, then bend it, i try to bend without cuts, but then the angle was too small.
    looks like you've fixed your fragmentation. just apply a loft cut with a path to get the chamfer…
    Yes i try, but the first 1/4 have a same width, and strait going up. then start to tightening but not too fast, thats why i have this problem.
    Like the fragmanted version.
    Delete all the chamfer and move face features you have tried. and use a loft as I shown in my image.if you are unfamiliar with lofts you can learn more at learn.onshape.com
    Hello
    i know the loft, but thats not working for me, because first its go straight up, and just then start the curve.
    And the straight part has a same widht, and just then start to tightening. but very low angle.
