Changing lookup table reference from an ENUM
Nath_McCNath_McC Member Posts: 136 PRO
edited January 2025 in FeatureScript
Hi All,
I am creating a "simple" feature script which swaps the lookup table for a different size table (Metric / Imperial set sizes).
I'm getting two issues which I hope are simple fixes but I can't seem to figure them out. Any help would be appreciated.
  1. I am getting a duplication error on the definition.sSize precondition. I understand this but I dont know how to make the definition.sSize either the metricTable or imperialTable
  2. getLookupTable; I was expecting a simple if statement and variable would switch the tables for the "sizeTable", "definition.sSize",
Thank you in advance.
export const metricTable = {
"name" : "metricTable",
"displayName" : "Wire Size",
"entries" : {
"2mm" : { "wireSize" : 2, "drillSize" : 3, "drillDepth" : 5, "outsideDiameter" : 4 },
"2.5mm" : { "wireSize" : 2.5, "drillSize" : 3.5, "drillDepth" : 10, "outsideDiameter" : 5 },
"3mm" : { "wireSize" : 3, "drillSize" :4, "drillDepth" : 12, "outsideDiameter" : 6 },
export const imperialTable = {
"name" : "imperialTable",
"entries" : {
"1/8" : { "wireSize" : 3.17, "drillSize" : 4, "drillDepth" : 10, "outsideDiameter" : 6 },
"1/4" : { "wireSize" : 6, "drillSize" : 7, "drillDepth" : 18, "outsideDiameter" : 12 },
export enum measurementSystem
annotation { "Name" : "Metric" }
METRIC,
annotation { "Name" : "Imeprial" }
IMPERIAL
annotation { "Feature Type Name" : "Sizes" }
export const myFeature = defineFeature(function(context is Context, id is Id, definition is map)
precondition
annotation { "Name" : "Select Point", "Filter" : EntityType.VERTEX && SketchObject.YES, "MaxNumberOfPick" : 1 }
definition.point is Query;
annotation { "Name" : "Wire", "UIHint" : "SHOW_LABEL" }
definition.measurementSystem is measurementSystem;
if (definition.measurementSystem == measurementSystem.METRIC)
annotation { "Name" : "Wire Size", "Lookup Table" : metricTable }
definition.sSize is LookupTablePath;
if (definition.measurementSystem == measurementSystem.IMPERIAL)
annotation { "Name" : "Wire Size", "Lookup Table" : imperialTable }
var sizeTable;
if (definition.measurement == measurementSystem.METRIC)
sizesTable = "metricTable";
if (definition.measurement == measurementSystem.IMPERIAL)
sizesTable = "imperialTable";
var wireSize = getLookupTable(sizeTable, definition.sSize).wireSize;
var drillSize = getLookupTable(sizeTable, definition.sSize).drillSize;
var drillDepth = getLookupTable(sizeTable, definition.sSize).drillDepth;
var outsideDiameter = getLookupTable(sizeTable, definition.sSize).outsideDiameter;
setVariable(context, "wireSize", wireSize);
setVariable(context, "drillSize", drillSize);
setVariable(context, "drillDepth", drillDepth);
setVariable(context, "outsideDiameter", outsideDiameter);
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,979 image
    In any precondition, you cannot use the same variable even if it is in a different scope. Rename them different, then use logic in the main code to use the correct variable depending upon the user selection.
