Is it possible to take a picture and turn it into an layout I can extrude
I am having trouble trying to get a picture to be turned into a 2d model that can be extruded on a solid back for 3d printing.
Is there a way to accomplish this on onshape or is there another site i could visit to do this.
  • MDesignMDesign Member Posts: 925 ✭✭✭
    if you talking automagicly turning it into an object. no. but if you want to take a picture then import it into a sketch and trace over the picture and extrude it into a 3d flat object then yes.
  • steve_shubinsteve_shubin Member Posts: 1,114 ✭✭✭✭
    @orin_elkins666
    There are programs that turn bitmap images into vector files such as Vector Magic.
    So it could be a matter of finding a program that saves in a vector file format that Onshape is capable of importing
  • eric_pestyeric_pesty Member Posts: 2,242 PRO
    I've used inkscape "Trace Bitmap" function to extract contours of an image as a DXF, then import into Onshape. The quality of the results may vary depending on what the image is…
