Named render modes
jon_loschkejon_loschke Member Posts: 32 ✭✭
edited January 20 in Community Support
Is there a way to make named render modes that I can easily switch between? I tried named views and display states but neither capture the current render mode, which is understandable for their intended purpose.
I use two to three render modes commonly, in both part studios and assemblies, and switching requires multiple changes to the render options panel each time. I would love to assign to a shortcut.
  • GregBrownGregBrown Member, Onshape Employees, csevp, pcbaevp Posts: 301
    You can assign custom keyboard shortcuts (in your preferences) that activate the various render modes.
  • jon_loschkejon_loschke Member Posts: 32 ✭✭
    Yes, thanks. Unfortuately, you cannot create a pseudo-macro by assigning the same shortcut to two different options, which is what I want. But this still much better than diving through menus. I did this with two keys adjacent on keyboard and it is workable.
    Alt-U-J unshaded, hidden edges
    Alt-S-X shaded, no hidden edges
    One more point: this is really a preferences type thing because I want it across all by documents. It is not something I customize per document or per tab. So ideally this customization would be available in the preferences section.
  • S1monS1mon Member Posts: 3,298 PRO
    You can set the defaults for these 3 menu items by right clicking.
    right, but I want to quickly flip between two sets of settings.
  • eric_pestyeric_pesty Member Posts: 2,158 PRO
    Doesn't quite solve your problem but you can have two browser tabs open of the same thing, one setup for each of your preferred modes.
    You are still going to have to set that up with every "session" (and every part studio or assembly) but it will allow you to switch back and forth (or even have both on screen at the same time.
    I'll try that
