Get lengths/position of points/lines from selected face?
Lauren_Froschauer
Member Posts: 10 EDU
I am trying to cut down on the number of user inputs for the box joint feature. I remember Kevin mentioning that I could query the length of an edge or the position of a point etc. from a selected face.
Kevin, which command were you referring to? Could you give me some example code using it?
distance is ValueWithUnits = worldToPlane(plane, worldPoint)[2];(this should probably just be in std)To get the length of an edge:
length is ValueWithUnits = evLength(context, {entities : edgeQuery});Is there a way to return the coordinates of the two vertices that define an edge by selecting the face that the edge belongs to?
qEdgeAdjacent(face, EntityType.EDGE)toevLength. To get the vertices of an edge, query for them usingqVertexAdjacent(edge, EntityType.VERTEX)and useevVertexPointusing either the evaluated vertex query or usingqNthElement.
