Linking Objects
How would i go about linking these two together using a tube? For example, point A to point B.
  • David_YL_NguyenDavid_YL_Nguyen Member, Onshape Employees Posts: 182 image
    Hi @dylan_ball058,
    Try these things:
    1. Share a (public) document so people can have a closer look to help out
    2. Create a sketch that connects point A to point B
    3. Sketch a profil for your tube that you want to use to connect the two points
    4. Use the Sweep command to create the tube along the path
  • MDesignMDesign Member Posts: 1,337 PRO
    I would just add that if the circles you are trying to connect are different sizes, you will need to use a loft with a path method.
