Smooth over step like with a spline
Gabriele_CannizzaroGabriele_Cannizzaro Member Posts: 14
Hi all
Probably not the best title, however what I'm trying to do is smooth over a step between two surfaces, but with more control than what fillet provides. This is a 2d sketch of the curve I'm trying to achieve:
That's with a constrained spline in a sketch, so I could mirror it, close the surface, then do a couple of extrude and remove, but I was looking for a more elegant solution. Is there one?
Thanks!
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 651 EDU
    Replace face is pretty elegant.
  • MDesignMDesign Member Posts: 925 ✭✭✭
    Another way might be just start with that outline (with the spline in the sketch and extrude it. I'm guessing this might be part of a bigger project so it needs to have a step in it first? If not, don't make it more complicated than you have to. sketch and extrude and done.
  • Gabriele_CannizzaroGabriele_Cannizzaro Member Posts: 14
    Thank you both, the solution with replace face looks like what I was after, though I had hoped there would be a single tool (like fillet) to achieve that rather than 3 entities. I'll try that!
    Was there a reason you can just do it all in one sketch and extrude? no need for surface or replace face based on final result of matt's example
    @MDesign apologies for the delayed response, I've tried both methods now and actually spline sketch plus extrude does feel easier to implement and control. I guess my original post was about whether a "variable fillet" existed, something like the chamfer feature which allows you to set two dimentions.
    Thanks all!
