i am creating a urdf file but getting this error pls help
kathirgamam_venkatesan
Member Posts: 2 EDU
Traceback (most recent call last):
File "/home/creator1705/.local/bin/onshape-to-robot", line 8, in <module>
sys.exit(onshape_to_robot.main())
File "/home/creator1705/.local/lib/python3.10/site-packages/onshape_to_robot/onshape_to_robot.py", line 17, in main
from .load_robot import File "/home/creator1705/.local/lib/python3.10/site-packages/onshape_to_robot/load_robot.py", line 142, in <module>
for occurrence in root["occurrences"]:
KeyError: 'occurrences'
Hi, I just recently had the same error.
It turns out the issue was with the config file.
Ensure that the document ID matches what you are working with. Same with the packageName and the other attributes in your config file
