Configuration name as option for export rules
felix_fischer992felix_fischer992 Member Posts: 7 EDU
edited February 2 in General
Please correct me if I am mistaken, but I think this is not currently possible.
I would like to be able to add the configuration as a suffix when exporting, via an export rule.
I am aware that I can change individual part names using the "Configured properties" option, however I frequently find myself wanting to export all the parts of a Part Studio simultaneously.
When exporting an entire Part Studio, there seems to be no easy way to automatically add the configuration name to the resulting file name.
Does anyone know of a workaround for this, or is this simply not a feature that is currently available?
  • raj_Onshaperaj_Onshape Onshape Employees Posts: 111 image
    Configuration name only makes sense if you design all your models with a single configuration list parameter. Otherwise it is not very straightforward what the name of the configuration should be.
    You can always create a new computed property and update it based on your input configuration parameter values and use that in the export rule.
  • eric_pestyeric_pesty Member Posts: 2,410 PRO
    edited February 3
    Or you can use something like the "property explorer" FS and a configured variable to append that information to the name or description (or any property…)
