Wire clip curves not included in the composite part and therefore unelectable.
chris_lambertchris_lambert Member Posts: 2
Hi, the curves aren't bundled into the composite part when creating clips using the Cable/Wiring Routing - Custom Features and therefore I can't select it for use in-context assembly.
Any ideas?  Thanks Chris
  • Matt_NCMatt_NC Member Posts: 10 PRO
    Not especially helpful, but I also appear to be having this issue!
  • theo_richardsontheo_richardson Member Posts: 4 PRO
    @NeilCooke I am also having challenges with a Network Clip - making a duct. Is this user error on my part? Are there any more guides for Wiring ducts / setting up Network Clips to ensure we are doing this properly?
    Thank you!
