Water cooled magnet coil
I have no problem sweeping profiles with guides drawn on horizontal or vertical planes. SWEEP 4 is an example of sweeping profile in horizontal plane.
When plane where sweep guides are drawn has an angular displacement with the horizontal plane the end sweeping profile has an angular
displacement. End profiles are not congruent.SWEEP 2 is an example. See the end profiles.
I tried lofting but have a problem. See LOFT 1. I have no problem lofting otherwise.
What am I doing wrong ?
Link to the coil is attached.
Thank you
https://cad.onshape.com/documents/156c99ec3a95471dae383010/w/f18840c39bce4ee68a489924/e/19b58d3bf469423d97eedb5e
Thank you
Below are the results of the geometric exercise (i have no idea how this geometry would be manufactured).
The exercise pointed to several pieces of functionality that have been noted as needing improvement - thank you.
https://cad.onshape.com/documents/bffc6353cf8c4b0ebd793e48/w/31580fdb229c447f9eb1213a/e/7ba17ec6fd034870accf662b
