Hanging dimensions
How do I add the two diameter dimensions illustrated in this image
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 898 PRO
    Those are diameters (note the diameter symbol, ⌀). Click the centerline, then the entity to be dimensioned, then move your mouse to the other side of the center line (in this case to the left).
  • Ste_WilsonSte_Wilson Member Posts: 551 EDU
    Ah-ha! I'd been wondering that as seen it on a couple of screen shots here.
    Does it also work when dimensioning up a drawing?
  • michael_marriammichael_marriam Member Posts: 10
    Thank you for the help. I knew I did an exercise that had that operation but I could locate it.
