How to use the API to execute a FeatureScript to create a custom feature?
I created a Part Studio and a Feature Studio in the same document.
Here is the content of the Feature Studio.
FeatureScript 2581; import(path : "onshape/std/common.fs", version : "2581.0"); annotation { "Feature Type Name" : "Fillet Everything" } export const filletEverything = defineFeature(function(context is Context, id is Id, definition is map) precondition { } { opPlane(context, id + "plane1", { "plane" : plane(vector(0, 0, 6) * inch, vector(0, 0, 1)) }); });
As you can see, this script simply creates a plane. Now, I need to use the Onshape Python API to call this FeatureScript in the Part Studio to create a plane. My Python code is as follows:
body = {
"btType": "BTFeatureDefinitionCall-1406",
"features": [
"featureType": "filletEverything",
"btType": "BTMFeature-134",
"name": "Fillet Everything 1",
"parameters": [],
"featureId": "FGMsohIYH03BN1f_0",
"subFeatures": [],
"namespace": "e03fd799aee4796bff7177d98::m4c232d7c5b8456deef0ccc33",
"nodeId": "QtTe+DBU77uVY1dM",
"returnAfterSubfeatures": False,
"suppressed": False
res = self._api.request('post', '/api/v10/partstudios/d/' + did + '/w/' + wid + '/e/' + eid + '/features',
body=body)
The content of the body is obtained by calling the getFeatures
API, so the body content should be correct. However, whether I use the Python API or the API Explorer, I am unable to create the plane in the Part Studio. The error message returned is as follows(from python):
"message" : "An internal error has occurred; support code 6a3cbb3b760a3d749babc43e",
"status" : 500,
"code" : 0,
"supportCode" : "6a3cbb3b760a3d749babc43e",
"moreInfoUrl" : ""
Besides that, I have also tried using other versions of the API, such as v9, as well as the default API, but none of them were able to create the plane successfully. I believe the issue lies with the FeatureScript, because I can correctly create features like sketches and extrudes using a similar approach.
The reason for using the API to execute the FeatureScript is that, through FeatureScript, I can create a sketch plane by directly specifying the point coordinates and the normal (using the newSketchOnPlane
function). Since my data only contains the Origin, normal, and x information, I have no choice but to use this approach to create the sketch plane
If anyone has experience with executing FeatureScript scripts in a Part Studio via the API, or if you have any insights into what might be causing this issue, I’d really appreciate your help!
EvanReese Member, Mentor Posts: 2,430 ✭✭✭✭✭
It's not clear to me why you need the API for this. I don't think it's an issue with your FeatureScript code (though you may want to rename it from "filletEverything")
I did my own test and got it working. Here's the FeatureScript and API body I used with glassworks.
FeatureScript
FeatureScript 2581;
import(path : "onshape/std/common.fs", version : "2581.0");annotation { "Feature Type Name" : "Add a plane", "Feature Type Description" : "" }
export const addPlane = defineFeature(function(context is Context, id is Id, definition is map)
precondition
// Define the parameters of the feature type
});API Request Body for POST/partstudios/d/{did}/{wvm}/{wvmid}/e/{eid}/features
"feature": {
"namespace": "e548d56ece749371a5a6ad6ec::m3e236759fa16868e79d8699e",
"name": "Add a plane 1",
"suppressed": false,
"parameters": [],
"featureId": "FFdDMAZL9at4Q6m_0",
"nodeId": "KG/OVwqfZXVDmvzg",
"featureType": "addPlane",
"returnAfterSubfeatures": false,
"subFeatures": []
}2
FeatureScript
FeatureScript 2581;
precondition
"feature": {
"parameters": [],
"subFeatures": []
Thank you very much for your response! I need to transfer some models from CATIA to Onshape, where the planes are defined by 3D points and normals. However, I couldn’t find a way to create planes using 3D points in Onshape’s API; it can only be done through FeatureScript. That’s why I chose this approach. (The FeatureScript example provided is just a very simple sample used to explore how to call custom features.)
And why wouldn't you just use STEP files? Are you trying to replicate parametric features?
@he_qiu143 , You got the support code, because the body of the add Part studio feature endpoint expects
feature:{}
, while in the example you posted you hasfeatures:[]
.Yes, Im trying to replicate parametric features
