FeatureScript fault
hansjuerg_jenzerhansjuerg_jenzer Member Posts: 16
I have a fault in this script.
mismatched input ')' expecting {'[', 'box', '::', 'boolean', 'number', 'string', 'array', 'map', 'builtin', 'function', 'undefined', '{', BOOLEAN, NUMBER, ID, STRING}
19:6 Feature Studio 1
Code:
FeatureScript 2581;
import(path : "onshape/std/common.fs", version : "2581.0");
annotation { "Feature Type Name" : "Set Part Appearance" }
export const stetPartAppearance = defineFeature function(context is Context, id is Id, definition is map)
precondition
annotation { "Name" : "Part to modify", "Filter" : EntityType.BODY }
definition.part is Query;
// Set the appearance with the desired transparency (0.5)
setProperty(context, {
"entities" : definition.part,
"propertyType" : PropertyType.APPEARANCE,
"value" : color(1, 1, 1, 0.5) // RGB (1,1,1) with 0.5 alpha for transparency
My idea: a feature script that sets the appearance to 50% when the part is actively selected.
Thank you for your support
Hansjürg
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,845
    defineFeature(
  • hansjuerg_jenzerhansjuerg_jenzer Member Posts: 16
    Hello Neil
    What exactly would you like to have better defined?
    The error message is there.
    “ mismatched input ')' expecting {'[', 'box', '::', 'boolean', 'number', 'string', 'array', 'map', 'builtin', 'function', 'undefined', '{', BOOLEAN, NUMBER, ID, STRING} ” In the last line at the second “ }); ”
    What should the script do?
    Set the appearance to 50% for a part activated with the mouse. However, the color should not be changed. This is certainly still wrong in the code.
    Thanks for the help.
    Hansjürg
    I was merely pointing out that you are missing a parenthesis after defineFeature.
    Thank you for the further explanation. It has helped.
    I am an absolute greenhorn in the script area.
