Rotating view locked on with mouse
hal_willishal_willis Member Posts: 2 ✭✭
Always after using Onshape for a few moments in Sketch mode, I cannot get my mouse to do anything but rotate the views, ESC, CTRL Windows key, space bar and a combination of all mouse buttons (Including the wheel), nothing "frees" up the mouse. Every time I have to abandon the drawing. I'm running Ubuntu 16.04 on an ASUS X550LA with 12Gb Ram, but that should not make any difference. My browser is Vivaldi latest stable version, which is Chrome based. Any help appreciated. Hal.
    Hi @hal_willis
    We only directly support Chrome, Firefox, Safari, and Opera.  While Vivaldi may work for most of the product, we don't make any guarantees that it will work in all cases.  I would somewhat expect this strange behavior to clear up if you just click the right mouse button, but if that doesn't work I would suggest you try one of the supported browsers.  If you see this behavior on any of them, please let us know.
  • jrs_spedleyjrs_spedley Member Posts: 71 ✭✭
    It probably isn't related but may be.  I use Opera with Windows 10 and when rotating if another window or tab takes focus then I'm stuck in rotate mode until I click and press escape.
    It may be something similar with Linux, I know there is an option to make any window which the mouse goes over to take focus and that may be your problem.
  • ricardo_monizricardo_moniz Member Posts: 2
    Had this issue with Opera, it's related from one of the browser's default settings. Go to setting and search for mouse gestures and turn it off, fixes the issue 😉
