why when i right click i dose it keep rotating after i have let go
  • glen_dewsburyglen_dewsbury Member Posts: 1,295 PRO
    edited February 2025
    I find myself unknowingly holding the right mouse button down because of the Parkinson's. On this mouse not much pressure is needed. I regularly get the RB menu when not needed.
    The question is 'are you inadvertently holding the RMB'?
  • The_M100The_M100 Member Posts: 20 EDU
    Could it be that the screen is catching up to your inputs? I sometimes see this happen sometimes in larger assemblies.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,979 image
    It sticks for me sometimes. RMB and rotate again and it should “release” it.
