Strange Sweep Behavior – Not Following Spline Path
MDesign Member Posts: 877 ✭✭✭
you will probably have to post a link to your document so everyone can see what's going on under the hood.
You will have better luck if your profile sketch is perpendicular to the path. I'd stick a plane using curve point on your sweep path and put your sketch on that plane
1 -
glen_dewsbury Member Posts: 1,057 PRO
The sketch curve used by handle sweep should go past the the outer surface of cup or it will leave gaps. Mate connecter on the end of handle sketch will line up the sketch.
https://cad.onshape.com/documents/f410f53df735fb6019c1a5e5/w/3ded63fbe21afede1179c626/e/0bff045112c487df48952a19
1
Hi, thanks for your support. Here it is: https://cad.onshape.com/documents/4c02289105af3c46850ad7cc/w/c442e5ad64ec477bc89d0850/e/e6acb617a365e5bee8c3c8d7?renderMode=0&uiState=67ac5ee7b7468c72c1d9b584
try flipping the plane of Toepfchen sketch
PS. If the handle over shoots inside, no problem. You use deleteface(heal) to get rid of it.
