Difficulties using guides with the loft
jean_dufetelle
Member Posts: 3 EDU
Hello, I'm trying to make a "trumpet like" geometry
however I'm having diffulties making work the loft function
I'm using parametric curves for trajectory and guides and the showed sections seem to make a valid geometry but it doesn't work
any ideas ?
https://cad.onshape.com/documents/796617a5bf23cfa4dfda655e/w/23b715c3062aeb69f881a9a5/e/dcda4eecb24fbcbc273769a3?renderMode=0&uiState=67adc843e699a61c87262858
Looks doable. Please make the document public so others can make a copy.
Made it public
The only change I made was re-creating your Sketch 2, using the Pierce constraint with the circle.
https://cad.onshape.com/documents/7b265f9547ea96d0c8af0858/w/a086dde488156e48d7b16a86/e/ce8281dba51dee0e72394a05
Oh wow, well thanks a lot, I could have passed hours not figuring that
