Renaissance - Big update and a new tool
I am excited to announce a new big update to Renaissance!
What is Renaissance?
Renaissance is a collection of automation tools for Onshape with one simple goal: to save you time.
As the leading provider of custom Onshape Apps, I end up with lots of ideas for useful tools for Onshape automation and really know my way around Onshape automation. Renaissance bundles all these great ideas together into one value packed product. New tools are added regularly, with 2 new tools slated to be added this year.
The current list of tools includes:
  •  Assembly component export (which can even export drawings and flat patterns)
  • Configured Part Export
  • Release export
  • Configured release parts
  • Configured drawing generator
  • Assembly Component Share
  • Configured Part Measured Variable Export
  • Find and Replace
Whats new?
This big update has had a big overhaul to the user interface and file exporting.
Previously, exports were all uploaded to the current document. This caused some confusion, as it wasn't always clear when the export was complete.
Large exports can take a while to complete, but we are now offering the option to have a download link emailed to you. No need to keep checking for that zip file.
The old option still exists, as we want to keep Renaissance flexible to meet all users needs.
Users now have their own settings profile in Renaissance.
Under the new settings tab, you will find options for export filenames.
Onshape export rules are supported, but you can also define Renaissance specific naming rules.
Renaissance has new help docs - all in one place.
Previously, the help documentation was a bit hidden away. The new documentation should be a bit clearer, and easier to find.
Find and Replace
The newest tool in the Renaissance toolbox - Find and Replace.
This app makes quick work of renaming by letting the user do a "find and replace" across a number of different fields in a document.
  • Part Names
  • Part Numbers
  • Part Descriptions
  • Tab names
  • Feature Names
How do I get Renaissance?
Simple -  Subscribe in the Onshape app store
Try for free for 30 days - after that its only $30/month per user.
Have lots and lots of users? Enterprise pricing is available, email for more info.
www.smartbenchsoftware.com --- fs.place --- Renaissance
  • Kevin_CowlesKevin_Cowles Member, Onshape Employees Posts: 50 image
    Love the update Caden! Excited to try out the new functionality
  • Caden_ArmstrongCaden_Armstrong Member Posts: 354 PRO
    Renaissance has another new update!
    A new tool has been added to Renaissance - "Remove Sketch Constraints".
    This tool will go through all sketches in a part studio and find constraints that are missing geometry, and remove the constraints.
    This is something that can happen if you are copying sketches between part studios or removing upstream geometry.
    A quick and easy way to clean up copied sketches.
    Subscribed today to get this and whole bunch of other great tools.
    New tools added regularly.
    edited September 2024
    Three new tools have been added to Renaissance, and the best part is that they new additions come at no additional cost. Renaissance is only $30/month providing great value with every update.
    Try Renaissance for free
    Image Cube
    The image cube app quickly generates a mosaic of a part from each of the orthogonal views.
    For configured part studios, images across a range of configurations can be generated to quickly check for bad configs.
    Configured Properties
    A common challenge that I've come across is creating configured properties when there are a huge number of configurations. Onshape supports copy/pasting from excel, but generating the actual rows in the table can be a challenge.
    With this new tool, Renaissance can generate the rows of your configured properties table for a given range of configuration parameters.
    Find and Replace
    This new tool lets you do a ctrl-f replace across a document.
    Find and replace feature names, part names, tab names, descriptions, and part numbers.
    This tool works within a single tab or an entire document.
    Useful for keeping organized data when creating document copies.
    The preview lets you make sure that all your data will be correctly updated.
    A new update for Renaissance is now live.
    This update includes a number of performance updates and two new tools:
    Assembly Mirror
    Working with symmetrical assemblies has never been easier. This tool inserts copies of selected components at mirrored locations.
    Multiface DXF
    This tool solves the workaround for exporting multiple selected faces as DXF. Great for working with the auto layout feature, but without having to rely on the workaround that involves creating a new drawing.
  • f_g214f_g214 Member Posts: 5 PRO
    Hello Caden,
    Thanks for your work to help the community.
    I really need mirror function in assemblies so I tried your Assembly Mirror.
    The result is not what I expected.
    Is it because the tool does not do what to do, or I don't understand how to use it?
    Example:
    I have a part in an assembly. Here the corner is on the origin, but it could be randomly positioned.
    What I want to obtain.
    With Assembly Mirror
    When I do the mirror as selected above, the result is a circular repetition on Y axis.
    I tried the 12 combinations Rotation Plane and Mirror Plane and have 4 positions as result.
    Is this tool can to what I need?
    @f_g214
    As you've discovered, the tool does not truly mirror (because that would require creating a new part). It is just doing a rotation and mirroring the position. The offset is because the part is sitting above the origin. If you move the part down in the z-axis by 1/2 the thickness, the mirror should work as you are expecting.
    I need to implement arbitrary plane selection in the tool for these situations (currently only the standard planes are supported), but I have been putting this off because I have been expecting Onshape to implement their own Assembly Mirroring function.
    Thanks for the explaination.
    I also hope that Onshape will release a mirror function soon.
  • MichaelPascoeMichaelPascoe Member Posts: 2,712 PRO
    edited March 2025
    This is dope!
    FYI: I promise I did not snitch the feature copy idea for cadsharp's app. I literally put something similar in it the other day. Different way of interfacing though.
    Renaissance has had some new updates.
    We've made big improvements to loading times, updated the UI, and added some new functionality:
    - Find and Replace now supports notes in drawings
    - The Magic Drawings app supports copying the part number to the current drawing from the referenced part
  • S1monS1mon Member Posts: 3,810 PRO
    What is the "Magic Drawings" app? Is that just for configurations or does that work for general drawing creation?
    The "magic drawings" app is a collection of smaller drawing automation functions. It started as a beta tool, I should really rename it to "Misc Drawing Tools"
    Importing CSV's as drawing tables
    Inserting inspection tables into drawings
    Setting the drawing part number (from the referenced part's number)
