Why is my assembly overdefined?
evan_evaniukevan_evaniuk Member Posts: 5 EDU
Sorry I'm still a beginner, but I cant seem to understand what joint is over defining my assembly. I just want to pull the finger down by pulling a solenoid back, but when i put the final revolute joint, it all breaks. If i suppress the slider joint and freely move it, then its perfectly capable of doing the motion I want, but once its in the form of a joint it all breaks…
  • wayne_sauderwayne_sauder Member, csevp Posts: 629 PRO
    @evan_evaniuk
    It is hard to tell without the document, but changing the last revolute mate to a cylindrical mate will probably work.
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,035 PRO
    Edu documents are read-only by default. You'll need to make it public for anyone to copy it and find the issue.
    Or, play around with it more, you'll probably find the issue.
