Issue with using the loft tool to cover some squares
evan_jones615
Member Posts: 4 EDU
I do not exactly know how to use forums, so apologies if I am using it wrong. However I do have an issue with making a shell for my model, it looks alright(-ish) and does have some clipping, I have some ideas on how to solve it. However…
I have no idea how to finish the top of the model.
https://cad.onshape.com/documents/806804c65479d4908422141a/w/1f6ac6ec1675a995dfa0ed0e/e/c8a65498772775e6aef89dda?renderMode=0&uiState=67af41cfaa638c78450faaef
I have only tried using the loft feature both as the same or separate procedure as well as using resolve and transform which provides a solution but not a smooth one I like.
I am also curious if it is possible to create a loft shape out of intersecting sketches like what is bellow
I wont mind any extra pointers. I find Onshape amazing yet there is still much for me to learn.
Matt_Shields
Member, Onshape Employees Posts: 844 PRO
Glad you're enjoying Onshape! It is an amazing tool, especially once you start taking advantage of the advanced surfacing capabilities. Four tips:
- Try out the surfacing courses in the Learning Center, such as https://learn.onshape.com/courses/introduction-to-surfacing
- Try the continuity options with the Fill tool for making caps.
- If your part has any symmetry, model half or quarter of the part, then mirror.
- If you want others to be able to look at your document, make it public.
Apologies for not making it public I thought I did hopefully this hyperlink would work.
I am grateful for the response as it does help me with another one of my odd works. However, I am having trouble fixing the top of the model even with the Fill tool. I could also have some recommendations on how to clean up and organise the feature tab. I do apologise if this is quite the bother for you.
