Trouble closing surface lofts
odd_jobodd_job Member Posts: 2
The problem seems very simple but I'm struggling to get these surfaces closed to form the shell of this mouse mod I've been working on. I've tried a number of permutations and it is fighting me each time. I've got extensive experience doing the same or similar in solidworks, the tricks I would use there haven't been helping me. I'm at a loss at this point what I'm doing wrong.
https://cad.onshape.com/documents/ca926954f297d4c84f3adeca/w/bea1b51049d7981e848c6230/e/9f2b9a547ad0a5e6a004c878?renderMode=0&uiState=67b1813b2c2c0c39a6228440
  • glen_dewsburyglen_dewsbury Member Posts: 1,124 PRO
    If you're Looking for something like extruding stubs up to the shell then you need to adjust the feature tree sequence or you'll have to do another extrude from the stub ends to next/surface.
    Personally I prefer to derive external parts first with out all the transforms for placement. No need even to specify locations and it will be at the origin. It will do better job of keeping sketches in the best position in feature tree and likely save a lot of steps. See example parts studio.
    https://cad.onshape.com/documents/9802eb707e0d885c4f943d99/w/1c85ab460e180586ae243751/e/07f85ce8173d7b6926738854
