opSplitFace with text
ben_partouch
Member, csevp Posts: 159 PRO
Hi,
When trying to split a face with the text sketch region, the feature picks up the construction lines created by the text feature and uses them for the split op as well. Why is that? I thought construction lines are not considered fully inclosed.
How do I fix it?
Thank you.
solved :)
var textEdges = qSketchRegion(id + "sketch2"); var loop = qLoopEdges(textEdges);
