How to remove cross lines from drawing?
andrew0221andrew0221 Member Posts: 2
I have a design I am going to cut out with a laser cutter, so I export it to a drawing so that I can export it as an SVG file. Problem is, when I try to insert the object into the drawing, it has cross lines that aren't removable and are included in the SVG file.
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 840 PRO
    right-click the view. show/hide. hide auto centermarks.
  • michael3424michael3424 Member Posts: 751 ✭✭✭✭
    Or right click on the face of the part in the Part Studio and select "Export as DXF", assuming that your laser cutter can read DXF files.
