help turning imported STL surface mesh into solid part
Hi everyone,
I have a bit of a problem.
I built a boat using a ship design programme for a project at university.
Now I want to continue using it and convert the hull into a boat to use as an RC boat.
Is there a way to get such a STL mesh into a part?
I'm a bit out of my depth with my skills so if anyone can help that would be really great.
Thanks in advance
https://cad.onshape.com/documents/b6092195daadda0dcd1167ed/w/016b22b28e15751e7039e920/e/55c963aa6e25a04ce2da48ba
  • glen_dewsburyglen_dewsbury Member Posts: 1,061 PRO
    Can open the linked part studio, For anyone in this group to view and make comments it needs to be made public.
  • martin_kopplowmartin_kopplow Member Posts: 828 PRO
    With the latest update that came out yesterday, you now have a new tool to create surfaces constrained by points. I believe this might be of great value when building clean surfaces on your imported STL model.
    I just gave it a try, mostly out of curiosity for the new tool. I derived your hull model into a new document to enable the new constrained surface tool, for existing documents aren't yet updated.
    It actually works, surprsingly well, also on your file, but to be brutally honest: Your STL model is of such evil quality that I wouldn't build a single thing upon it, but rather rebuild it from proper sections and guides. Because I'm curious: What was the name of that ship design application you used to create the hull and what was the objective which lead to this strange potato shaped hull?
    edited March 14 Answer ✓
    I couldn't get the original surface to mesh and had to split it. Bit tricky to thicken as well. Had to add a fillet to beak sharp edge along keel. The new constrained surface 🤗 sure helped. I have to agree with Martin on the quality of original STL surface.
    https://cad.onshape.com/documents/f28e6c46ee519bb0f097d2bb/w/2f99b0196e2fd82df01209ea/e/cee5edbe6f3fe85fb09336dd
  • MDesignMDesign Member Posts: 896 ✭✭✭
    depends on the mesh. you'll have to figure how to make your document available for others to see.
  • georg_bühnertgeorg_bühnert Member Posts: 5
    Okay now it is publick. https://cad.onshape.com/documents/b6092195daadda0dcd1167ed/w/016b22b28e15751e7039e920/e/55c963aa6e25a04ce2da48ba?renderMode=0&uiState=67d3ebfdf44ca37f3c2b0b4d
    Okay the document is now public, have togth wit the link is is automnatilcy publick
    edited March 19
    Thanks for the help, I have started to try and do it myself and failed.
    Normally I use Delftship and Bentley to calculate the ships, it is mainly a calculation program for normal sized ships. So the triangles are not optimal for small curves. So not optimal for this ship, but I am comfortable with it.
    The shape is not optimised for stability in waves, so it does not move that much. In the real world, the Ulstein X bows are the inspiration. They look fancy and have a lot of advantages in theory, if that is the case I want to test this model after 3D printing in the towing channel at the university.
