Color text or layer properties in drawings?
scott_caskey
Member Posts: 53 PRO
When are we going to be able to add color to our dimension text or other text on drawings? Layer properties?
I'm constantly amazed at how clunky OnShape is when you get to the 2D drawing phase.
6
For color options:
If you open the Drawing Properties pane on the right side of drawings, you'll find some options:
You'll find line weight & style options, as well as color options for dimensions, notes, title block elements, etc.
It is possible to get creative with those and have certain colors and line weights assigned to each.
For example, one of my drawing templates doesn't have anything in the border zone. So, if I have annotations I want to apply a certain color to, I can move them to the border zone layer, and apply my color to that layer.
Unless I am missing something - I cannot seem to add an additional layer in the 'Formats' category under the properties menu which, typically is where I would add such an option. So 90% of my original template is incredibly hard to read by comparison to the template I issue on AutoCAD. It's not 1980 anymore... Regardless of typical drawing standards we need the ability to change colour quickly and effectively. (I do appreciate this may be in the working - or hopefully so) but it is a big issue.
Did you create a drawing or are you talking about sketches? It sounds like you haven't created a drawing yet.
When are those planned improvements supposed to be captured? Also want to add on here that the "layers" are all active simultaneously for selection so you can screw up your border lines and title block lines when making a drawing.
@Boice We released a style panel quite a while ago now and have updated many times as well:
Improvements to Onshape - March 14th, 2022 — Onshape
