relict
Severin_123Severin_123 Member Posts: 47 PRO
edited March 2025 in FeatureScript
  • jelte_steur_infojelte_steur_info Member Posts: 650 PRO
    have you tried this sequence of operations manually?
    does the extrude work? (debug the extruded bodies and comment out the boolean for testeing)
    perhaps there's something with the extrude (e.g. up to next) that's not compatible with sheet metal…
    can you share your document for more in context help?
