How do I connect vectors in a sketch?
korbin_strong
Member Posts: 5 ✭
No matter what I make the lines are all disconnected in DXF causing my arc droid to have to cut 2 separate L's instead of just a square in one go. The problem with that is that I have double the lead ins and outs and it making it hard to keep the lead ins and outs from hitting other parts near by. On top of that It makes a perfectly straight line have a little notch in it, even with a lead in and out. I know that a plasma cutter isn't crazy accurate especially on an Arc Droid but still super annoying. Oh, and doing coincident constraints on everything Doesn't make a difference at all. Doesn't matter if I'm making a square from default or from lines. Sometimes It's opposing corners and other times it's 2 corners next to each other and every once in a while its every corner. When I put my DXF file into Vcarve or Light burn from a buddies place, they both have some kind of combine vectors option. There's also a good chance I'm dumb too, lol.
Can you post a document link and a DXF file that doesn't work for you? It's possible that whatever your putting the DXF into could be the issue.
This site says I cant share a DXF file. but here is the link.
https://cad.onshape.com/documents/79cf47e8db19bb6c39a53b5a/w/78530d6ea17e4b5b7ca732ed/e/9e9f7ffad554d372b426dbea
You would have to put it in a zip file. but I don't see anything in your onshape model that would cause disconnected ends. The problem is likely on the machine end when it interprets the file. maybe try exporting DXF to an older/different version that the machine is compatible with. I'd be surprised it that works but worth a shot.
