Rounding fault?
hansjuerg_jenzerhansjuerg_jenzer Member Posts: 16
Hello everyone
I have been having a problem with rounding edges for a few days now.
If I want to round the four corners of a body (e.g. 50x50x5mm), this is no longer possible in one rounding operation.
As soon as I select the second corner, I get an error.
I assume that I have changed something somewhere and not that it is a (new) onshape problem.
Can anyone help me?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,889
    Change Measurement type from Width to Radius.
  • hansjuerg_jenzerhansjuerg_jenzer Member Posts: 16
    Hi Neil
    Thank you
    At that moment I also found it.
    As soon as you do it right, it works.🤣
