"extrude" curved letter
hi,
I'm using projected curved to convert letters to curves on curved surfaces. I then convert the curves to faces (surfaces) and use offset surface with loft to "extrude" the letter
it works well for most of the letters except closed letters like o (i didn't check q of p or d…).
you can see in the picture that the loft for o didn't work (it's red) and the loft for E is working
https://cad.onshape.com/documents/8ce39354117f0d31df72cf62/v/d40e9affeed8af4919f71b04/e/8abfcb8d73940457c32f8d37Error
i can fix it with bridging curves but that lots of work for a single loft (its even worst when the letter is a closed rectangle) .
  • MDesignMDesign Member Posts: 1,259 PRO
    seems like the thicken tool would simplify this for you
