Question on Thread Creator
I created Nut and bolt both with diamter 8 mm. Then I added ISO-Thread, tried both 1 and 1.25 mm pitch. After exporting to stl and printing, there is no way that both fit. Should the diamter for inner and outer thread be different?
  • klaus_krämerklaus_krämer Member Posts: 60 ✭✭✭
    edited March 2024
    In my experience it's necessary to use different diameters. Screw threads (external threads) are cut into the cylinder and fit quite well using the intended thread diameter (e.g. 5mm for ISO M5).
    Nut threads or internal threads are added to the cylinder surface. It's not logical because the should also be cut out of the borehole.
    Currently I use 5 mm for screws and a borehole of 5.4 mm for nuts. Printed with these dimensions, they are fully compatible with ISO M5 threads on metal screws and nuts. Probably varying dependant on your 3D printer and nozzle size. Simply test it.
  • giuseppe_cattaneogiuseppe_cattaneo Member Posts: 11
    If you are 3D printing both bolt and nut, is better not to use threadcreator for nut. better subtract the bolt form a full nut with boolean using offset all parameter with a 0.2 offset or similar.
  • michael3424michael3424 Member Posts: 735 ✭✭✭✭
    External and internal thread forms have slightly different specifications, which is necessary to avoid the two threads interfering with each other. See the data in this link:
    https://www.engineersedge.com/screw_threads_chart.htm
    or run your own searches. If you have access to a library (or a machinist) take a look at Machinery's Handbook which has dozens of pages on various thread forms and their specifications. The data has largely remained unchanged for decades and you can find used copies fairly cheaply in used bookstores or on Ebay.
  • jonathan_gunnjonathan_gunn Member Posts: 2
    thank you this helped me a lot. however it won't let me do an offset of anything less than 0.4mm and I'm not sure why
