Populate a circular pattern in Assembly
duncan_wood309duncan_wood309 Member Posts: 2
If you have a part with a cirular pattern, of a hole for instance, that you've brought into an assembly and you mated another part to that hole, how can you poluate that part to the circular patern of the first part?
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,030 PRO
    Replicate is one option. Assembly pattern is the second. I'd probably try replicate first.
