Where are my templates?
Member Posts: 2
I created a document and uploaded my standard drawing templates (.dwt files). When I create a drawing tab in a document, there is nothing listed under "My templates" or "Created by me".
  • Member, OS Professional, Mentor Posts: 2,476 PRO
    Sounds like you did everything according to instructions
    Things to try / check
    - are your files actually .dwt format (not like template.dwt.dwg)
    - refresh browser and download fresh data into cache (shift+refresh)
    - repeat whole process to find out if something went wrong
  • Moderator, Onshape Employees, Developers, csevp Posts: 218
    @frank_walsh You did everything correctly.  This is an issue that is currently being investigated.
  • Member Posts: 2
    Great. Thank you.
