Where are my templates?
frank_walshfrank_walsh Member Posts: 2
I created a document and uploaded my standard drawing templates (.dwt files). When I create a drawing tab in a document, there is nothing listed under "My templates" or "Created by me".
    Sounds like you did everything according to instructions
    Things to try / check
    - are your files actually .dwt format (not like template.dwt.dwg)
    - refresh browser and download fresh data into cache (shift+refresh)
    - repeat whole process to find out if something went wrong
  • cody_armstrongcody_armstrong Moderator, Onshape Employees, Developers, csevp Posts: 221 image
    @frank_walsh You did everything correctly.  This is an issue that is currently being investigated.
  • frank_walshfrank_walsh Member Posts: 2
    Great. Thank you.
