Why is everything so slow
So Ive run into another issue I cant seem to diagnose. All of a sudden my file is running at a crawl. The last time this happened it was because I had designed the entire project and all its parts in a single part studio. Thats not the case this time. The project is separated into its major parts, all with their own part studio. Admittedly it was fine for a little bit but started slowing down as I went into the fine detail. I avoided using a dwg/dxf for it as I was told (and have experienced first hand) the severe drop in speed when theyre in use and instead basically "traced" the details I wanted. Thats where the issue started and Ive been seeing a severe drop in my speed ever since. I was just trying to use the design to "circular pattern" onto the Sheath for Extrude/Remove. Its not my computer as I've tested on a few. Other projects work fine as well. Only thing I can think of is that maybe I made the design I was recreating TOO small and detailed, but that is my only idea. Ive also reached out to support who suggested returning to a previous version but thats not really feasible at this point. If anyone could take a look and put a new set of eyes on it Id greatly appreciate it. The detail in question is in the "Sheath" part studio under "Snake Skin Design Base". Thanks in advanced.
https://cad.onshape.com/documents/528b65b5761318532c10540a/w/b75e6fea9b677e5eb42a89c9/e/199023fdde2899d5fff45d6f?renderMode=0&uiState=67d01d650b75117bc5dabbb5
My guess would be a lot of unconstrained sketches, at least from my experience sketches can become very cumbersome when not constrained.
Even if that's not the case, I highly recommend making sure sketches are constrained properly, at the very least to each other.
