Dimensioning a length of a Curved Object
matt_davies955matt_davies955 Member Posts: 3 EDU
edited March 13 in Drawings
Trying to determine the length of an object for this engineering drawing. How do you measure a curved object in this instance to note its length and width. We tried adding a node (point), in the sketch but this does not help in the drawing
Cheers
  • S1monS1mon Member Posts: 3,628 PRO
    You can show the sketch and dimension the points, but what might be easier is to split the surface(s) with the midplane, which will give you points in the main view.
  • martin_kopplowmartin_kopplow Member Posts: 991 PRO
    ... or use the recently introduced split edge FS, which will also create the dimensionable point on the edge but leave the face in one piece.
