How can I create a cologne casing showing how the cologne will fit inside the casing
Something like this
  • MichaelPascoeMichaelPascoe Member Posts: 2,803 PRO
    edited March 2025
    To do this you will need to take measurements of the bottle then model it in an Onshape part studio. Or you could use an iPhone to scan it, but that currently doesn't work very well due to scanner resolution.
    After you model the bottle you will be able to use it as a reference to create the case.
    Features you will most likely need are:
    - sketch
    - variable
    - extrude
    - revolve
    - fillet
    - boolean
    To learn how to do this you will need to complete the introduction learning pathways:
    RENDERCAD
