Why is this Remove Extrude operation not working?
jared_jajared_ja Member Posts: 12
Hey everyone. Back again with another beginner question that likely has an obvious solution im not seeing. I am attempting to do a "Remove" extrude and every time I do the extrude fails and presents a red line over the entire sketch plane. As far as I can tell there shouldn't be anything to hick it up.
I attempted to check each portion of the sketch itself to see if they were able to extrude normally and they were all fine with exception to these 2 portions.
Again, near as I can tell, I don't see anything that should cause the extrusion to fail. Ideally my goal is actually to have the area around the design (it itself being an enclosed shape) to be the target of the Removal, but the same issue occurs when its selected. Given the issue I have a suspicion that the solution is simple but I'm just not familiar enough with the platform to troubleshoot it. Still trying to wrap my head around it. Ive included the link to the project below. Any help would be appreciated.
https://cad.onshape.com/documents/528b65b5761318532c10540a/w/b75e6fea9b677e5eb42a89c9/e/f3bafaedf999a49f89bd45f1?renderMode=0&uiState=67c72668f3632a0ea1035d59
  • EvanReeseEvanReese Member, Mentor Posts: 2,456 ✭✭✭✭✭
    After a bit of hunting it seems like the curves that create the failing shapes have some sharp corners in them, even though they are a single continuous spline. In other words the radius of curvature is zero in some spots. You can find these by using the curve analysis tool like so. Edit these somehow and it should work.
  • jared_jajared_ja Member Posts: 12
    Yeah that worked out just as you said. Even helped me diagnose some other issues elsewhere. Thanks
  • gert_bothagert_botha Member Posts: 3
    Hallo all
    As relative new user, I experienced the same issue - has driven me nearly insane! 😉 Even also tried Revolve (to Remove) - same happened…
    In my case, the cause was trying to cut away from an incomplete or invalid model. Before this attempt to cut away material in some other area, there were few minor Delete Face actions listed higher up in the feature tree, not yet followed by operations to close the resultant open surface gaps in the model. I was editing an imported model created by somebody else. After first deleting those early Delete Face operations, Extrude-Remove worked correctly.
    Problem is, or what confused me, is that the fault message from trying to execute the cut, appeared to be something quite irrelevant to the actual problem (time and again it complained about some of the Extrude-Remove parameters - "Merge scope" if I remember correctly.
    Regards
    Gert
    Gert, tough to diagnose without access to your document, but "merge scope" is the list of parts it's supposed to cut or add to. Possibly, some of your actions took a solid part (closed and watertight) and made it a surface body (with a hole somewhere), which would cause something like that.
