Best way of limiting to certain kind of materials
jan_vil
Member Posts: 9 ✭
For example I want to build a chair out of 40x20mm square tubing. Is there a good way of limiting myself to only use this material when building up a sketch? And to later know how many meters worth of the material was used (or get a cut list)
And the next question would be if it's possible to limit myself to the amount of material I have. ie i have only 2 pieces of 3000mm worth of material,
I'm sorry if this question has been asked before but for now I didn't find a good answer yet, and i'm also pretty new to this.
MichaelPascoe
Member Posts: 2,681 PRO
The easiest way to do this is with the Frame features. You can learn how to use them here: https://learn.onshape.com/courses/frames-fundamentals
About your second question. Yes, you can use equations, variables, and custom features to have your part studio cut list optimized to fit a specific length of material.
There are some other nice solvers here by Caden and Neil: https://forum.onshape.com/discussion/comment/112200#Comment_112200...
CADSharp - We make custom features and integrated Onshape apps! Learn How to FeatureScript Here 🔴0 -
eric_pesty
Member, pcbaevp Posts: 2,471 PRO
You want to use the "frame" tools (I suggest going through the learning center)…
Value solver by @Konst_Sh
