how to query for all vertexes in a mesh
tommie_berrytommie_berry Member Posts: 12 ✭✭
  • tommie_berrytommie_berry Member Posts: 12 ✭✭
    Yes, it is easy to extract all vertex points from the .stl file. Sorting them into each plane of the original scan is very difficult. The original scan planes are all parallel. I used the 3D points program in featurescript to create 3D splines, but you can only loft between 2D splines. So you have to create 2D closed splines from all the points close (<0.1mm) to one scan plane.
    then go to the next plane. So I agree, I can use the extracted points from a csv. But it would have been so much easier to query for all the points.
    Thank you, that was very helpful.
    if you could send that code to tom@berry.org I am very interested.
    edited April 2019
    I have a part studio with just an imported mesh.
    I want to loop through all the vertexes in the mesh using featurescript.
    Perhaps positing in the FeatureScript forum?
    Philip Thomas - Onshape
    That’s where I thought it was, I wish I could delete it.
    @TimRice - can you help Tommie get this down and moved to the FeatureScript forum - there he will get a snippet that does exactly what he needs.
    I reposted over there, please delete this one, sorry😜
    edited April 2019
    Hi Tommie,
    There is no direct way to iterate through every single point in a mesh in FeatureScript. A user may select individual mesh points into a query parameter, but not all at once. If you are looking to do mathematical calculations on every single point, FeatureScript may simply not be the right solution for you.
    We do support many ways of identifying specific positions on a mesh surface. For instance you can find the closest point to another point/plane/body with evDistance, or find a point along a ray with evRaycast.
    So, what's your use case?
    @tommie_berry
    We don't expose mesh vertices to FeatureScript.  If you do a qOwnedByBody on a mesh, you'll notice that a mesh is basically just one composite face:
    https://cad.onshape.com/documents/f8b3df73f921b5ed6b03e0a3/w/180340618b58cdd57349a22f/e/899f59ff6132240c25fb70df
    This simplification allows us to increase user performance when working with meshes.  Please submit an Improvement Request for us to expose this information, or to create some kind of workaround function to expose a list of the locations of the vertices.
    What is your desired feature here?  Maybe we can suggest a different approach.
    If I could get the list of mesh points, then I could read a 2D spline for each original plane from the scan. Then I can loft between those 2D splines, to create an object I can edit.
    @billy2
    The code block should be fine as long as you create the code block first and then paste into it.  If you paste and then highlight and click code, it looks bad.
  • GregBrownGregBrown Member, Onshape Employees, csevp, pcbaevp Posts: 366 image
    Just for correctness/completeness, now (March 2025) we have evMeshPoints that will help a lot of the things you've been wanting to do.
