Joining different sketches on separate planes?
in Drawings
I have two different sketches on planes spaced 16in apart. The sketches are similar, but not identical, so I can't just exude the original. But I just need basically a solid part made to fill the space between the two sketches.
You might need to invoke the "Vertex Matching" option from the loft dialog, if the result is twisted.
BTW: A point of terminology: You've posted this (perhaps accidentally) in the "Drawings" category, but it is categorically
not a Drawing question
(Sketching, in this context, is a Modelling function)
