Sweep along split line
graham_lock
Member Posts: 265 PRO
graham_lock
I edited the initial post and corrected a syntax error on the sweep.
The code shown now works.
1
Hi,
I'm trying to workout how to sweep along an edge created by a split in FS as can be done in the UI.
The outline of my code is:
// create plane at angle - THIS WORKS
cPlane(context, id + "bodySplitter", {
"entities" : qCreatedBy(id + config.longeronIndex + "skLine", EntityType.EDGE),
"cplaneType" : CPlaneType.LINE_ANGLE,
"offset" : 0 * millimeter,
"angle" : planeAngle,
"oppositeDirection" : false,
"flipAlignment" : false,
"flipNormal" : false
// split solid body with plane - THIS WORKS opSplitPart(context, id + "splitPart1", { "targets" : config.solidBody, "tool" : qCreatedBy(id + "bodySplitter", EntityType.FACE) }); // use sweep to create a body using previously sketched profiles - - THIS NOW WORKS sweep(context, id + "sweep1", { "bodyType" : ExtendedToolBodyType.SOLID, "operationType" : NewBodyOperationType.NEW, "profiles" : config.longeronProfiles[0].sketchRegion, "path" : qNthElement(qCreatedBy(id + "splitPart1", EntityType.EDGE), 2), "profileControl" : ProfileControlMode.NONE });The sweep throws an execution error.
I have a test document here which shows what I'm trying to achieve using the UI:
https://cad.onshape.com/documents/b47247537a19de65742c7ceb/w/a1f3a56d0c6bdd4de138c226/e/135b3120a9f5267d9588c24a
Any help appreciated.
Thank you.
