3D Texture
antoine_richermoz
Member Posts: 11 ✭
in General
Hi, I design parts for 3D printing and I this is what I would like to to :
You see this very fine surface pattern ?
This is what I would like to do in Onshape (or other software)
Do you know how to do it ?
Link: https://cad.onshape.com/documents/d42fe111947b2ac57f13cf8d/w/195abfeacad37bc3f1ba4eaa/e/e2196b9e56998b2b7db99de8
1) The end caps are simple 2D patterns. The grill is a simple fill pattern (https://cad.onshape.com/documents/57361ad4e4b00e5012c3857c/v/eb8bfe2edd984a315033e6e2/e/14aa44d127806651b248b9c6)
2) This is doable - it's pretty manual unless you want to write a custom feature to automate this.
3) The end caps and grill can be made with the 'lighten' feature. The facetization can be created manually, or automated with a custom feature. (https://cad.onshape.com/documents/573f7d70e4b0fddafb52148c/v/a8a36f6d743269e1b6886711/e/2dc22a6a95896a5243812d07)
4) The ornate grill is a simple pattern. The end caps are not something that a b-rep modeller can easily handle. This type of geometry is not something that you will want to do in Onshape (or any other modeller - eg SolidWorks)
Another custom feature that may help is the surface pattern feature.
https://cad.onshape.com/documents/6988ff60065e4c34350ca5e1/w/05b4b3df185502c24c426678/e/5609d290e6b16e8c2a12cf12
So if b-rep modeler can't really do this what type of software can ?
And also I think you messed up your last link.
The best answer i can give is not really a good answer. Those kinds of very small scale perturbations are very hard to generate.
However you go about it, the end result is likely to be simply an STL file.
The workflow will probably include some elements of;
Either a brep or surface modeller generating the feet and lion heads
Perhaps a polygonal modeller for the perturbations- eg 3D -studio max or Mesh Mixer (and to combine the feet and heads)
Perhaps a generative solution (eg Rhino + grasshopper).
Perhaps a 3D scan of a hand carded model.
Again - that last case is very hard - how did you make the geometry shown?
I think the surface pattern will suit my needs.
I did not make any of the example above, this are from a Bluetooth speaker from a company named V-Moda, and I thought their designs were really creative.
How do you make the pyramid? I used the rollback tool to see but when I come to the Pyramid it only shows a square.
You can extrude a square with draft 45 degrees inwards. Just make sure you extrude it enough
How do you only select the diamond to Linear.
https://cad.onshape.com/documents/3064452f9da08dc085e30315/w/e9723f1c55354cea2e3e5387/e/d4cd4d44a5ab1a708af2921f
I understand that for most people the detail needs to be very refined and smooth, but for the purpose I have, a simple displacement map from a hires image would be fine. I have wondered about trying to write a plugin, but it's a bit deep-end for a first try at plugin dev.
It would be a really useful feature for people designing minifig terrain or other models.
I want it in the basic modelling stage because often I need other features to align with the produced model (for example, if I do a tree-trunk texture with a knot-hole and a branch base, I then want to subtract some of the truck from the hole to make it deeper, and place a branch aligned out of the base.
I'm sure this is something complex, but oh how I'd like a simple "apply displacement to surface" feature that let me modify a surface to add or subtract (or both) a bitmapped displacement map.
RenderStudio (Professional and Enterprise) has bump maps.
See for example: https://cad.onshape.com/help/Content/render-studio-resources.htm#metal-grill-with-custom-cutouts
