Putting countersunk holes on a wrapped part around a cyclinder
I have a cylindrical piece that I want to add a lens (which will have an LED strip in the lens). I want to use countersunk screws to attach the lens to the cylinder body.
1. How do I create countersunk holes on the Lens (in grey)
2. How do I extend the holes into the body (in blue) who they will be tapped when I 3d print the body.
https://cad.onshape.com/documents/76a23c08609acee7752f555b/w/5cef716fd78c28d6e8aac42c/e/540056ab2b7cf18ebf1ccac5?renderMode=0&uiState=67e065e748d9c8025a87621d
Thanks in advance
Terry
  • glen_dewsburyglen_dewsbury Member Posts: 1,307 PRO
    Here is sample of one of the ways to do this. Including the holes with the wrap causes some distortion(stretching).
    https://cad.onshape.com/documents/fe0d45038bf2628fdfada069/w/a3913ceb0eaabf791fea09ed/e/84f54dc063de1db5910287b0
  • terry_schumacherterry_schumacher Member Posts: 4
    @glen_dewsbury
    Thanks for the quick reply. I have a few questions before I admit it is solved, even thought It looks like it is.
    I want to verify the steps and why so I'll know next time.
    1. You altered the wrap so you selected the entire Lens Outer Edge Sketch, NOT including the wholes I had.
    2. You create Sketch1 based on a MP you placed at the top middle edge of the Wrap 1 (Lens).
    3. On this sketch (Sketch 1), you then created a construction line thru the center line of the part for each set of holes I had draw. (I'm not sure where you got the angles?)
    4. You created the 5 holes (the 2 end holes and the three that were along the side) by creating an MP based on the construction lines from Sketch 1.
    5. You then did a Move face to move the middle three holes to one of the sides. I've never used the Move Face command, I'll have to read u on that.
    6. You then mirrored the three holes you moved in the previous step along the center line of the part based on a MP
    I see I need to learn a lot more about MP's to be able to use them like this.
    Thanks again for the quick reply.
    MP? MC (mate connector) They're worth studying since they can speed things up and eliminating planes in the feature tree. https://cad.onshape.com/help/Content/mateconnector_a.htm?Highlight=mate%20connecter'
    That's not angles but arc lengths taken from your flat sketch.
