Custom Feature Icon for Dark Mode
ethan_keller924ethan_keller924 Member, csevp Posts: 44 PRO
I've noticed that std features seem to have two different icons - one for dark mode and one for light mode. Is there some secret to making this work with custom feature icons? For instance, see below how the Derived and Sketch feature change colors, but all that happens to the custom icons is the changed background comes through the transparent part of the svg, which washes out the dark lines. I think dark mode is still in beta, so it is possible this still isn't supported, but figured I'd ask :-).
Screenshot 2025-03-21 at 3.09.37 PM.png Screenshot 2025-03-21 at 3.09.44 PM.png
  • lougallolougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,015 image
    @ethan_keller924 Dark mode is a complex thing and in the design we tokenized many of the colors so our system knows the flip colors for dark and light mode. Today, you would need to just pick icon colors that work best with both modes. We may publish a set of color tokens that can be used in the SVG to ensure the some of the darker tones to icons know how to properly flip. This is not something we have documented or published outside of our internal design system.
  • ethan_keller924ethan_keller924 Member, csevp Posts: 44 PRO
    Thanks Lou! Makes sense. Then please consider this an improvement request to expose that eventually.
  • EvanReeseEvanReese Member, Mentor Posts: 2,869 PRO
    I'd use this for sure. I'm running into the same thing.
