I need a little help
I have one last error in my script that I can't get rid of.
Thank you for your support
Hansjürg
CODE:
FeatureScript 2559;
import(path : "onshape/std/common.fs", version : "2559.0");
// Annotation für den Feature-Typ
annotation { "Feature Type Name" : "Grid Generator" }
// Definition der Feature-Funktion
//export const GridGenerator = defineFeature; function(context, id, definition) {
export const GridGenerator = defineFeature;function(context is Context, id is Id, definition is map) {
// Precondition für Parameterdefinitionen
precondition {
    annotation { "Name" : "Grid Spacing" }
    definition.spacing is LengthParameter({
        "default" : 10 * millimeter,
        "min" : 0.1 * millimeter,
        "max" : 100 * millimeter
    annotation { "Name" : "Rows" }
    definition.rows is IntegerParameter({
        "default" : 10,
        "min" : 1,
        "max" : 100
    annotation { "Name" : "Columns" }
    definition.columns is IntegerParameter({
        "default" : 10,
        "min" : 1,
        "max" : 100
    annotation { "Name" : "Origin" }
    definition.origin is VectorParameter({
        "default" : vector(0, 0, 0)
// Erstellung des Skizzenobjekts auf der definierten Ebene
const sketch = newSketchOnPlane(context, id + "sketch", {
    "plane" : plane(vector(0, 0, 0), vector(0, 0, 1))
// Vertikale Linien zeichnen
for (var i = 0; i <= definition.columns; i += 1) {
    skLineSegment(sketch, "vertical" ~ i, {
        "start" : definition.origin + vector(i * definition.spacing, 0, 0),
        "end" : definition.origin + vector(i * definition.spacing, definition.rows * definition.spacing, 0)
// Horizontale Linien zeichnen
for (var j = 0; j <= definition.rows; j += 1) {
    skLineSegment(sketch, "horizontal" ~ j, {
        "start" : definition.origin + vector(0, j * definition.spacing, 0),
        "end" : definition.origin + vector(definition.columns * definition.spacing, j * definition.spacing, 0)
// Die Skizze lösen
skSolve(sketch);
Fault:
extraneous input 'precondition' expecting {'annotation', '[', '+', '-', 'return', 'if', 'for', 'while', 'new', '!', '++', '--', '::', 'function', 'operator', 'undefined', 'break', 'continue', 'var', 'const', 'try', 'in', 'switch', 'throw', SEMI, '{', '(', '}', BOOLEAN, NUMBER, ID, BUILTIN, STRING}
12:5
Feature Studio 1
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,965 image
    edited March 2025 Answer ✓
    Compare and contrast - this is why you should not use ChatGPT, it's not even close…
    FeatureScript 2615;
    import(path : "onshape/std/common.fs", version : "2615.0");
    annotation { "Feature Type Name" : "Grid generator", "Feature Type Description" : "" }
    export const gridGenerator = defineFeature(function(context is Context, id is Id, definition is map)
        precondition
            annotation { "Name" : "Grid spacing" }
            isLength(definition.spacing, { (millimeter) : [0.1, 100, 100] } as LengthBoundSpec);
            isInteger(definition.rows, { (unitless) : [1, 10, 100] } as IntegerBoundSpec);
            isInteger(definition.columns, { (unitless) : [1, 10, 100] } as IntegerBoundSpec);
                        "sketchPlane" : plane(vector(0, 0, 0) * millimeter, vector(0, 0, 1))
            for (var i = 0; i < definition.columns; i += 1)
                            "start" : vector(i * definition.spacing, 0 * millimeter),
                            "end" : vector(i * definition.spacing, definition.rows * definition.spacing)
            for (var j = 0; j < definition.rows; j += 1)
                            "start" : vector(0 * millimeter, j * definition.spacing),
                            "end" : vector(definition.columns * definition.spacing, j * definition.spacing)
            skSolve(sketch);
    Looks like ChatGPT to me - don't trust it.
    Should be:
    export const GridGenerator = defineFeature(function(context is Context, id is Id, definition is map) {
    Also, no such keywords as LengthParameter, IntegerParameter, VectorParameter
    Use the code snippets in the menu at the top of the Feature Studio for the correct syntax,
    Why rejected answer?
  • MichaelPascoeMichaelPascoe Member Posts: 2,763 PRO
    edited March 2025
    The best place to learn FeatureScript is here. It isn't to hard and doesn't take too long either, you just have to watch the lessons. 😎
    Onshape's FeatureScript Fundamentals Course
    CADSharp's FeatureScript Course
  • hansjuerg_jenzerhansjuerg_jenzer Member Posts: 16
    Thank you for trying to help me.
    I am an absolute greenhorn at feature scripting and have spent hours working with Perplexity and CahtGPT to come up with the above code.
    Only the last error I can't get rid of.
    It doesn't help much if you point out the lessons I need to learn. Which ones in this specific case?
    I'm quite willing to learn something, but general hints won't get me anywhere:
    What do I want to do anyway?
    It is not possible to show a screen grid in Onshape. I would like this to give me a rough overview of the dimensions and the relationships.
    This code should show a sketch with a line grid in it. If I can also set the spacing, that would be great.
    is also wrong
    It's not wrong, you need to close the parenthesis at the end of the code too.
    Well Neil already answered the question, I was just elaborating on how to not have this issue in the future:
    Which lesson? All of them =)
    The lessons are incremental, so each one builds on the previous lesson. This means you need to start at lesson 1. They teach you the foundation of FeatureScript so that you will understand how to make all kinds of features.
    Hi Neil
    That doesn't really help.
    Here is the new code and the error messages
    Here s the code:
    FeatureScript 2559;
    export const GridGenerator = defineFeature ( function(context is Context, id is Id, definition is map) {
    precondition {
            "default" : 10,
            "min" : 1,
            "max" : 100
            "default" : 10,
            "min" : 1,
            "max" : 100
    // Die Skizze lösen
    skSolve(sketch);
    Here are the faults:
    > 9:44 Error in inializer function arguments
    > 9:46 missing TOP_SEMI at 'function'
    > 11:5 extraneous input 'precondition' expecting {'annotation', '[', '+', '-', 'return', 'if', 'for', 'while', 'new', '!', '++', '--', '::', 'function', 'operator', 'undefined', 'break', 'continue', 'var', 'const', 'try', 'in', 'switch', 'throw', SEMI, '{', '(', '}', BOOLEAN, NUMBER, ID, BUILTIN, STRING}
    Hansjürg
    FeatureScript 2615;
        precondition
            skSolve(sketch);
  • _anton_anton Member, Onshape Employees Posts: 510 image
    Yeah, you shouldn't use LLMs for this. They don't replace understanding, especially for a specialized language like FS. You'll get a nice-looking snippet quickly and then spend a hundred times as long finding the issues.
    Michael's suggestion is really the answer here. Failing that, search the forum for custom features that already do this, or find similar custom features and understand their code.
    Hello Neil
    Many thanks for that.
    It looks much clearer and more logical, even for a layman.
