Help! Challenge: Fretboard Generation
michael_flynn102
Member Posts: 2 ✭
Hey! I'm trying to generate a guitar fretboard based off of configuration parameters, and I'm having a hard time figuring out the best way to go about it.
The challenge is that I need to essentially perform a function on each instance of a linear pattern to determine the distance to the next instance, instead of setting just one distance between each instance.
So far I have successfully used FeatureScript to generate the distances I need, but I'm not sure the best way to implement these distances, as I would LIKE for the end result to work with any number of frets entered and then generate a fretboard with that many frets. This is complicated by the fact that the face of the fretboard is a drafted curve, so just copying an object in a straight line won't really work as the angles won't be perfect.
I have this feature script to generate the variables I can use to manually put in each fret in the proper location, but ideally I'd like to write FeatureScript to generate all of the frets.
annotation { "Feature Type Name" : "Generate Fret Spacing Variables" }
export const addMyFunctions = defineFeature(function(context is Context, id is Id, definition is map)
precondition
annotation { "Name" : "String Length" }
isLength(definition.stringLength, LENGTH_BOUNDS);
annotation { "Name" : "Fret Count" }
isInteger(definition.fretCount, POSITIVE_COUNT_BOUNDS);
var c = definition.stringLength;
for (var i = 1; i <= definition.fretCount; i += 1)
var p = c;
c = c / 1.059463;
setVariable(context, "BL" ~ i, c);
setVariable(context, "OL" ~ i, p - c);
setVariable(context, "NL" ~ i, definition.stringLength - c);
setVariable(context, "NeckLength", definition.stringLength - c);
In the above code, the prefixes mean:
- NL: Nut Length (Distance from top of string to fret)
- BL: Bridge Length (Distance from bottom of string to fret)
- OL: Offset Length (Distance from previous fret to this fret)
Here is my project, versioned V0.3 at time of writing: https://cad.onshape.com/documents/39121782acf88719d61983ae/w/4d7fdf89d456b54d1055a07d/e/5162cd4f7ed9efedfdb77ad6
The best idea I currently have is to try to split the neck at the set distances, and then insert a sketch circle at the top / front most position in each chunk and sweep it across the top edge, and then merge all the chunks back together. But I would love some other suggestions.
Thanks in advance!
I wouldn't use variables at all. Do it all in the feature. You can select (or create) the fretboard and either select a modelled fret or even better, create the fret in the feature then use opPattern to create the others.
Do you really want to create a feature for this? it could be done with incrementing variables.
@GregBrown explains well in this video how to.
for #i, you could use my increment variable feature as well.
in this case it doesn't make much of a difference, but it would
I didn't know about this little trick with the iterations before. Great find! I did that manually for a bass build I have under way, but I believe a FS that incorporates the steps would still be a nice thing.
Nice feature @jelte_steur814! I had tried to come up with ways to make variable feature patterns easier for users but never quite was able to. This simplifies it really well.
RENDERCAD
This FeatureScript provides a different approach: https://cad.onshape.com/documents/9f2f3a64ab4def8cff234d9a/w/a48cd6ce490619b9b58d10be/e/d4b75bb996effcd056a83d7f.
I'm not sure who created it, but it could have been Steve Shubin.
It provides a pretty elegant solution that provides the ability to capture the fret positions as lines on a drawing, useful for CNC or laser cutting of the frets slots. Unlike Greg Brown's approach, this one does not model the frets, themselves, just the centreline of their location. One of the things that it does differently is that it intersects a plane with the surface of the fingerboard at the location of each fret. (It uses a linear pattern to accomplish that.) The resulting curve is then used to split the surface of the fingerboard into pieces, one surface in between each fret. On a drawing, the bounding edge of each surface appears as a line demarcating the centreline of each fret location. That can be exported for use with CNC or laser, for example.
I commented out the lines of code for the functionality that I didn't want, such as creating circular fret markers ("dots") and removing material in the fingerboard to match the fret markers.
