How do I make a Loft of sorts that will make a "curved ramp"?
joao_drummondjoao_drummond Member Posts: 8
I want to fill that area with a loft of sorts, that respects the curvature and "eases" the ramp until it reaches the end.
How may I do that?
https://cad.onshape.com/documents/95348026f22336243da5298c/w/4954531794b31370f3012f6a/e/9ff6052f079dd476ea8925f3?renderMode=0&uiState=67e749df5017516de822cc39
  • MDesignMDesign Member Posts: 1,286 PRO
    sketch the profile you want on the bottom then connect it with a 3d spline/curve or 2 for the curvature you desire. Create loft with the new sketch and the existing end profiles and add the new spline/curves as guides to the loft
  • joao_drummondjoao_drummond Member Posts: 8
    I had to redo some sketches that were wrong prior, that's why I wasn't being able to use Loft properly
    Now it seems to be working fine.
