Draft up to face or vertex?
félix_souan
Member Posts: 2 EDU
Hi, as you can see in the image, I have this mounting slot that I want to draft up to the bottom face of the cylinder. Any tips on how I could achieve that?
You can create a Ruled surface tapered from the edge of the cylinder and Replace face the flat surface with that. That would give you angular control of the surface. If you need the surface to taper from that edge and intersect the boss apex at its original position, a revolved surface might be better.
